Forum: Old versions
Topic: u46dj config..
what is the set up like for the u46dj because i saw one for the may44 usb but didnt see one for this
and also when setting this up what do i do to set up the configurations in virtual dj if someone can give me some tips i will definitly buy the real one instead of having the demo
please help
geposted Wed 11 Oct 06 @ 5:33 pm
listen2PRO InfinityMember since 2005
its the same setup with hardware, in vdj you will be able to select the u46 under soundcard options.
if you buy a u46 with a 50 in the serial use 1.014 driver
if it has 51 or 60 in the serial use 1.016
geposted Wed 11 Oct 06 @ 5:37 pm
