Topic: Vdj4.1 problems (bcd2000)
cosmodkPRO InfinityMember since 2006
Ive got a few problems
1. BCD2000 is laggy on the play button when i use the native bcd function, however on midi map it works as it should.
2. Cue button dosent stop and cue as its supposed to on native it just jumps to cue and play, but in midi map it stóps and cues.
3. Still having trouble with my MOTU 828Mk2 Asio soundcard, can only map 1 stereo output and not 2, i have to use a second soundcard that crashes my computer from time to time to get it working (maudio 410) This problem came with the VDJ4 the previos version mapped the 828Mk2 just fine as it should.
Thats all for now Hope the great support god in heaven will shin upon my problems and give me a solution to theese problems.
Kind regards
Cosmodk
geposted Fri 13 Oct 06 @ 9:31 pm
yes, cue_stop doesn't work like it should and is working like hot cue ,you can use your xml file to work with the bcd meanwhile if this new native support doesn't fit you, there are some bugs in which dev staff is working hard, hope in future version we have a mapper like mk2,regards.
geposted Fri 13 Oct 06 @ 10:09 pm
