HI,
I want to somehow in VDJ 4.1 Pro, pick songs I want to play for later in the night, but while I am at home. This would be at home prior to shutting down my computer system.
If I pick the songs at home and then put them in the "side list", they are gone when I re-open the program 2 hours later.
I don;t want to make a playlist as to an exact order, etc just a place where I can see 10 or so songs I want to remember to play that night.
I see under PLAYLISt management an option called MAKE VIRTUAL FOLDER. And I made one and named it PLAY TONIGHT, but things kind of aren't staying or it isn't exatly letting me add more and more things to it.
Can this be done??
thanks!!!!!!!!
Can this be done??
thanks!!!!!!!!
geposted Fri 13 Oct 06 @ 11:30 pm
Make a playlist and SAVE it ;) That will be one way
Or make a Virtual Folder...
Both ways will save your entries you want to keep
geposted Fri 13 Oct 06 @ 11:36 pm
Now-
you are right the virtual folder works- I just was messing soemthing up and looked like it was gone, but it ws there (left something in the search at the top)
thanks dude!!!!!!
thanks dude!!!!!!
geposted Sat 14 Oct 06 @ 12:00 am
