Forum: Old versions
Topic: audio problem when controlling vdj v4.1rev2 & v4.1
labdoreHome userMember since 2004
I notice since the new audio engine after v3.4, that here has been audio interference when controlling VDJ with a mouse.
What happens is I could be playing a track on 1 of decks and setting the next track up on the other. As the bass is playing on current deck you could do a one of the following. Spin the other deck in position, adjust the volume for the deck or move the slider into starting position.
you will hear low level interference like a grumbling sound faint I know sound funny but as I spin the deck into position you can hear it. I have a 5.1 sound card setup.
Great work by the way guys, I also just tried that tractor 3 and this beats it hands down keep up good work.
geposted Wed 25 Oct 06 @ 1:46 pm
DJ-ALFPRO InfinityModeratorMember since 2005
You should set lower setting in the Performances tab, your PC is not powerfull enough for the current setting. Try also to diselect safemode and overclock and turn off keylock and try than.
geposted Wed 25 Oct 06 @ 5:37 pm
sbangsPRO InfinityMember since 2004
you can find that in
main settings > proformances
move the slider closer to fast in small steps until the problem stops
, glad u like it i personaly agree much better than tracktor!
geposted Fri 27 Oct 06 @ 3:56 am
