I've been using VDJ 3.2 for ages, I tried 3.4 but it keept crashing.
However, I've bought a new PC and 3.4 works OK, but does crash every so often.
I've downloaded the updates, but havn't dared install them because the skin and the way it works was too different (until v4.1 rev2) because I used to have the visual effects and pictures on the screen alot.
However I think it's about time I installed v4.1 rev2 from 3.4. I will have to get used to the way the visuals and pictures work or go without some of the old features. But can you save me some headache?
What do I need to do? Do I need to back up my database in some way so I don't need to re-analyse all the music ?
Also I've got a NU04 mixer. Had it a couple of month's but not had the time to try it out. Is there a guide on how to get it to work with VDJ anywhere?
Cheers
Gaz
Cheers
Gaz
geposted Fri 27 Oct 06 @ 3:05 am
hi mate ,
al u need is this
click me
hope that helps
skyfxl
al u need is this
click me
hope that helps
skyfxl
geposted Fri 27 Oct 06 @ 3:10 am
Great! That looks like it will help. Thanks.
But it looks like it might take a while!!!
Same with setting up the FS2 Amp as an ASIO sound card and the NU04 mixer. I can see a couple of late nights ahead :(
geposted Fri 27 Oct 06 @ 3:17 am
il see if i can find some info for u :)
geposted Fri 27 Oct 06 @ 3:18 am
howdy
i dont have my copy open now but
basicaly i think ur mixer may be natively supported in vdj 4 so u can simply tick , that device on
if not
u need to map the midi signals to keys , u can do this from the midi section of the remote control
as for ur amp im not sure will keep looking
if not
geposted Fri 27 Oct 06 @ 3:24 am
So far so good.....
But what do the little orange circles next to some of the MP3s on my song list mean ?
I know a little green V is a video, and a little K is Karaoke (whch to me looks like the video symbol if you don't look close which is annoying). and a red circle with a black cross if it's been played.
Thanks for your help so far.
geposted Fri 27 Oct 06 @ 3:42 am
orange is the software advising you not to mix the songs together as it will be difficult
this is only a warning
you can still play these files but its recommended you do not use atomix mode with them
geposted Fri 27 Oct 06 @ 3:46 am
Cool. Everything's working I think (just need to plugg my hercule's MK1 Console in to see if that still works?).
I havn't got a clue where to start with The NU04 mixer? I've loaded some midi controll thing, and the green light is lit up in VDJ config when I go to controller's. But that's all. None of the button's do anything. It's going to be something really simple in the end.
Cheers.
Cheers.
geposted Fri 27 Oct 06 @ 3:55 am
the dj console mk1 should be fine :)
try opening and closing vdj a couple of times
that may solve it
that may solve it
geposted Fri 27 Oct 06 @ 4:03 am
OK just done my 1st gig with v4.1 rev2 however, the video's are useless. They are way more "Jerky" than before.
I used to be able to play a video and put the next one on a loop before bringing it in. Now when I try both video's go jerky. It's like having the strobe effect on constantly. Is there a setting I need to alter.
Apart from that everything else is great. The PC is brand new, 3.4 Pentium dual core, plenty of memory, decent graphics card etc... Like I say it used to play OK in 3.4 and just go jerky sometimes. Now with v4.1 rev2 it seems to go jerky on just about every video :(
Thanks in advance for any tips.
geposted Sat 28 Oct 06 @ 3:58 am
try lowering your proformance slider to fast , preferences > profomances
what card do you use for video?
geposted Sat 28 Oct 06 @ 11:09 am
My Graphics card:
ATI Radeon 9550 256MB (128bit) DDR Graphics Card with DVI TV Model Number: C3D 6055
Click Here For The Official Page
http://www.ati.com/products/radeon9550/index.html
The Radeon 9550 provides real DX9 power to the mainstream and allows gamers to experience the beauty of next generation graphics. With balanced precision, the Radeon 9550 will produce realistic dynamic lighting, soft shadow effects, DX9 shaders, and bump mapping all at new levels of image quality and performance.
Technical Specifications:
- Memory: 256MB DDR
- Memory Bus Width: 128bit DDR
- Outputs: VGA, DVI, TV
- Interface: AGP 4/8x
Click Here For More Info
Bought from: www.svp.co.uk
Price: £48.99
Can you suggest a better one?
- Memory: 256MB DDR
Price: £48.99
geposted Sat 28 Oct 06 @ 1:25 pm
I will see how it goes tonight. 18th Birthday party so that should be a tester.
I've just tried it at home, but it still stutters whenever I load a video and the performance setting is on fastest.
Its's reading the video's off a SATA-II hard drive so don't think that's causing the stutter on the playing video when I load the next. Any ideas?
geposted Sat 28 Oct 06 @ 2:09 pm
how much ram do you have mate?
did you try the slider?
geposted Sat 28 Oct 06 @ 5:27 pm
2Gig Ram. Pentium 3.2Ghz (D) Dual Core
Yes slider is set to fastest.
Could it be a problem with AVI files? As I have had to change the codec decoder to Windows Media.
geposted Sun 29 Oct 06 @ 1:55 pm
it could be
geposted Sun 29 Oct 06 @ 3:52 pm
