for some reason when I scratch with the vocal effect on my machine boggs down. After finishing the scratch it continues just fine.
I thought this would be fixed with 4.1, but I saw no change.
I have a topic under software support but have not had and responces on it.
you can find more detail there.
http://www.virtualdj.com/forums/54396/Software_Technical_Support/Severe_freezing___chopping_with_VDJ_4.html
any ideas?
David
any ideas?
David
geposted Fri 27 Oct 06 @ 6:01 am
hi there mate
try lowering the proformance slider to fast
in preferences > proformances
this should remove the strain on your pc
geposted Fri 27 Oct 06 @ 12:09 pm
I guess you didn't read my other post from the link. When I lower the proformance settings it gets worse.
David
David
geposted Sat 28 Oct 06 @ 12:03 am
its the same for me (and i would guess most people) its allways seemed to be that way. i think its cause the effects dont just process an audio signal but have to pre-read data to make it all smooth with low latency and when you scratch etc this is messed up. have they got rid of the massive latency on the VST effects yet?
geposted Sat 28 Oct 06 @ 2:11 am
