Hello, I'm checking VDJ 4.1r2 trial, the "disable autosync or beatlock (manually, on load, etc.) button" isn't working in the config panel, in previous version 3.4, the automix works great, aligning both decks in the first and last CBG of each song and without having to press any button, like "B" button in 4.1. Now you have to be always in front of the computer to press it, and it's supposed to do that in the auto feature, isn't it?
I'm expecting to buy this program, I think it is the best software (for real), but I need to know if you are going to fix this or add it in a next version. I own a bar and I use the automatic things a lot, I've created my playlists and edited each songs.
Thank you so much.
OMG.
Thank you so much.
OMG.
geposted Sun 29 Oct 06 @ 8:03 pm
how can u be a no licence user with atomix mp3 lol?
thats very odd
it should just load automaticaly
have u clicked the little wand icon ?
in the playlist
that should autoload
thats very odd
in the playlist
geposted Sun 29 Oct 06 @ 8:11 pm
The auto load is not the problem, the auto align is (cbg's). In 3.4 goes great (disable sync or beatlock button in config panel) and the songs are locked in their first and last cbg, catching them perfectly, but in 4.1 you need to be pressing "b" button, so, that button in the config panel isn't working right (I don't remember the name, I think it's called "disable beat lock" or something in config panel.
I hope that you really understand my problem.
Thanks.
Thanks.
geposted Mon 30 Oct 06 @ 8:43 pm
