Forum: Old versions
Topic: MAYA 44 USB ADIO ERROR..
I hope someone can Help.. I have a MAYA 44 USB with the 2.53 drivers and windows XP home on a compaw CORE DUO laptop. WHen I first turn on the unit I have to plug and unplug the maya 44 usb cable several times from the computer - sometimes 5-10 times before the system and virtual DJ will recognize all the ASIO channels. Once it recognizes all is good. I have tried to uninstall and reinstall the 2.53 driver but I still have the same issue, How can I resolve this?
geposted Tue 31 Oct 06 @ 8:00 pm
Perhaps what you need is to reinstall your usb drivers, it looks like if they are not recognizing the interfase, try to connect it to a 2.0 port.
BTW:check your usb cable is in good condition or replace it
geposted Wed 01 Nov 06 @ 4:14 am
hi,
if you use something else in your usb ports, it might be a power failiure. You should try a powered usb hub.
geposted Fri 03 Nov 06 @ 12:15 pm
djejPRO InfinityMember since 2004
Also, 2.5.5 is the latest drivers for the Maya 44 usb, you might try that. You can get it from the audiotrak website.
geposted Mon 06 Nov 06 @ 8:46 pm
