Forum: Old versions
Topic: Microphone level on default 3.4 skin
radiofcPRO InfinityMember since 2006
I am unable to locate a level control for the microphone on the default skin or config settings - am I blind or is it just not easy to locate?
After installing another skin I now have a level which allows me to adjust the microphone level. It defaults to zero and is not linked to the adjusting of the level on the MK2 although this is probably intentional as the MK2 mic volume control is really for talkover level.
I don't mind using this other skin but I am curious as to where the mic level control is to be located on the 3.4 default skin...
geposted Wed 08 Nov 06 @ 11:54 am
sbangsPRO InfinityMember since 2004
do edit mic level you need to download a plugin this is available to pro users
geposted Wed 08 Nov 06 @ 4:42 pm
