Forum: Old versions
Topic: shortcut settings panel?
Is there a keyboard shortcut to get to the settings panel in vdj? Because I installed a skin, and I can't find (or it doesn't work) the settings button. There is a button called '?' but it does nothing when I click it... :)
By the way, it's the skin called 'Numark TTX1 VDJ'. You have to choose 'show all submissions' instead of 'show best submissions' which should have warned me ;) But do not install it if you don't know the answer to this problem :)
Anyone know what to do for me to change my skin, or do I have to reïnstall?
geposted Wed 28 Jul 04 @ 10:33 am
I got it, I just deleted the skin from the skins directory, and restarted vdj. It starts with the default skin then. :)
geposted Wed 28 Jul 04 @ 11:39 am
the numark skin is not all up to date I think, needs an update to work properly... but glad u found a solution before trying a reinstall ;) lol
geposted Wed 28 Jul 04 @ 2:10 pm
djzeroPRO InfinityMember since 2003
yes it is a change in the command in the XML file. it is possable to creat a shortcut to the settings pannel, just click add: system: settings and asign a key
geposted Wed 28 Jul 04 @ 2:18 pm
thanks all
geposted Wed 28 Jul 04 @ 3:08 pm
