Forum: Old versions
Topic: changing from dual view to Clone mode.
Last night I wanted to change from dual view to clone to show what was on the screen instead, so I went to windows settings and unclicked "extend my window to second monitor". But then nothing appeared
on the second monitor. Is there another settings table somewhere that I should be using to check "Clone " screen on other monitor?
geposted Mon 20 Nov 06 @ 7:43 pm
phillydjPRO InfinityModeratorMember since 2004
If you gonna run clone mode and dual mode , make sure that u do it through the video cards software not windows
If you enable the second monitor on windows it assumes that its for dual mode and might conflict with thye video cards software
also make sure before you do so, to disable the whole video output from VDj (just in case)
geposted Tue 21 Nov 06 @ 3:51 am
My question was how to I get to the video cards software to run clone mode. Couldn't locate anything?
geposted Tue 21 Nov 06 @ 4:30 am
you have to go through your video cards software , not windows ...check the advance tab under the desktop properties you should see something there (what card is it)
geposted Tue 21 Nov 06 @ 4:32 pm
ATI x300 or sumpin like that. Found it Philly.
Thanx, and Happy Thanksgiving, guy?
geposted Wed 22 Nov 06 @ 12:54 am
Happy Turkey Day to you too!!!!
geposted Wed 22 Nov 06 @ 9:34 am
