Hi Guys,
I do have a lot of trouble when mixing two soundfiles from different sources.
Also: I started to like more and more the sound of vinyl.
Could you guys give any hints about how you do when you wanna
mix in a .wav file from a vinyl source with one from a CD?
Also: I really like the vinyl sound more than the cd sound.
Is there any way to compress the cd sound, or any filter I can apply
to my cd wave files in Adobe Audition to let is sound 'warmer'?
Some explanation:
- All my CD's and Vinyls are recorded on my harddrive as .WAV files (44Khz).
- I record with Adobe Audition
- I do a little normalisation after recording my vinyls
- I do use Orhtofon Concorde cartridges
Thanks for all input on this subject
Some explanation:
geposted Thu 23 Nov 06 @ 8:04 am
there is a vinyl sound plugin you can download to add that authentic sound here
http://www.virtualdj.com/addons/effects.html
geposted Thu 23 Nov 06 @ 12:12 pm
Hi Skyfxl,
I looked up the effects addon you proposed.
This one is adding vinyl noise to your music *grin*.
I'm not really into having more noise on my wave files.
I'd rather have my cd's sound like vinyl waves (spectral range and stuff like that, not noise).
Anny other suggestions? :-)
geposted Thu 23 Nov 06 @ 12:27 pm
