Forum: Old versions
Topic: VDJ 4.1 Time Strectch
Hi all,
Forgive me if this question has been asked before but i have tried searching the forums for an answer to this with no joy,
Is it possible to disable time stretch with VDJ 4.1 ? i just simply cannot see any settings for it,
Regards
Ph4nt0m
geposted Fri 24 Nov 06 @ 11:26 am
sbangsPRO InfinityMember since 2004
do you mean the matching of bpm
if so go to
Match bpm : never
i cannot find a time stretch option either
geposted Fri 24 Nov 06 @ 11:37 am
Hi, thanks for the speedy reply but it's not the Match BPM i'm looking for,
In VDJ 3.x, there was a setting under the fame tab to enable or disable timestretch so that when you increase the speed of a track, the sound level would not change, it apears that this timestretch is now set to on by default in VDJ 4.x but i need to turn it off,
Any further help with this would be greatly apriciated,
Regards,
Ph4nt0m
geposted Fri 24 Nov 06 @ 11:51 am
enable keylock this will dissable time stretch i think
its the padlock symbol under each deck
geposted Fri 24 Nov 06 @ 1:03 pm
Give that man a Cigar :o)
Many thanks skyfxl, thats absolutly spot on !!!
geposted Fri 24 Nov 06 @ 1:21 pm
any time :)
geposted Fri 24 Nov 06 @ 1:36 pm
