Forum: Old versions
Topic: Treble, Medium, Bass eq problems
MHansenPRO InfinityMember since 2006
Hello!
I’ve just started to use VDJ Pro, and I’m getting trouble from the Treble, Medium, Bass eq.
When I place the knobs to +/- then I can’t hear the changes in my headphones, only on the output channel to the amplifier.
Do anybody recognize, or know a solution for this problem?
Regards
Mads Hansen
Denmark
(There is no problem when I use the VDJ Console Edition software)
geposted Fri 24 Nov 06 @ 5:11 pm
sbangsPRO InfinityMember since 2004
geposted Fri 24 Nov 06 @ 5:14 pm
Lovely!
Thank you :)
/Mads
geposted Fri 24 Nov 06 @ 5:33 pm
any time :)
geposted Fri 24 Nov 06 @ 5:42 pm
Hello, I just used this registry tool after a long time of missing the eq in my headphones since the upgrade to 4.0. When I run the tool, it works perfectly to fix the eq issue, but the vdj does not load the full track when I drag to a deck. It pulls up the beatgrid and any ques but does not show the wave form. Any ideas? Thanks, Chris
geposted Tue 19 Dec 06 @ 7:19 am
try reseting the registry (reset on tool) and reaplying the options
geposted Tue 19 Dec 06 @ 4:22 pm
Still no dice. I've gone through it three times re-entering all my settings, and everytime I finish the track still does not load. It seems to happen only when I make the headphone eq change. I suppose its not a huge deal, I'm going external soon : )
geposted Thu 21 Dec 06 @ 12:35 am
Change max-load setting in VDJ options;)
Set max-load to longer than what your music files is (for example 30 mins)
geposted Thu 21 Dec 06 @ 1:12 am
Fantastic! Thanks
geposted Sun 31 Dec 06 @ 9:07 am
djcelPRO InfinityModeratorMember since 2004
Hum yes, I need to correct : "always" causes trouble
geposted Sun 31 Dec 06 @ 2:21 pm
