with automix function, songs dont enter sincronized. How can i fix that?
geposted Thu 30 Nov 06 @ 10:04 pm
choose in main config
always match pitch
always match bpm and always match
and force fade
always match pitch
and force fade
geposted Thu 30 Nov 06 @ 11:19 pm
Sorry if Im being very stupid but were is always Bpm match? I´m using 4.1
geposted Fri 01 Dec 06 @ 1:21 am
at config menu - options -auto pitch match
geposted Fri 01 Dec 06 @ 1:39 am
Ok I see Thanks :D
geposted Fri 01 Dec 06 @ 9:28 am
Also if the safe mode is on under the config/perfomance tab, un tick it.
geposted Sat 02 Dec 06 @ 2:10 am
what does safe mode do exactly?
geposted Sat 02 Dec 06 @ 11:07 pm
just to check
got these settings:)?
geposted Sat 02 Dec 06 @ 11:10 pm
yes
geposted Sat 02 Dec 06 @ 11:17 pm
okies
how about on the mk2 control pannel?
geposted Sat 02 Dec 06 @ 11:21 pm
í need to mix a couple songs voor a performance for school, so i downloaded Atomix trialversion.. but i dont understand how it works!! i really dont.. and i need the mix tomorrow so can ANYONE Pleaseeeee help me?? xQuinC..
geposted Sun 03 Dec 06 @ 5:18 pm
check the mix lessons forum:)
geposted Sun 03 Dec 06 @ 5:23 pm
