Forum: Old versions
Topic: soundcard configuration on ver 2.01
Probably, i'm just the only one but......
there was a VERY usefull option on the last version i haven't found on that new one!
Why or where you can configure every single channel to a different output from the soft to the soundcard?
geposted Sun 01 Aug 04 @ 10:49 am
its still there... just a bit more "hidden" in the new easy to use interface.
Look for advanced settings :) it's the second last image if you scroll down in soundcards setting
hope that helps
geposted Sun 01 Aug 04 @ 10:51 am
thank you very much!
Silly me!!!!!
now, everything s just FINE!!!!!!
thanks again norway!
geposted Sun 01 Aug 04 @ 11:14 am
no problem ;) just glad to help
geposted Sun 01 Aug 04 @ 11:18 am
can you tell me how to enter ADVANCE CONFIGURATION MENU?Where is the tab?
geposted Thu 09 Sep 04 @ 6:23 am
It can't work in a cracked version.
geposted Thu 09 Sep 04 @ 6:45 am
djlarsPRO InfinityMember since 2003
deja-vu all over again...
geposted Mon 13 Sep 04 @ 8:10 pm
