Forum: Old versions
Topic: @****Right Deck Was Possessed
Last night I was in my last 15 minutes of a 5hr Xmas party.
I was playing on the left player “Wild Thing” And Sampling on the right player “Push It”, looping the first Messier.. Half way through the song all hell broke loose.
The Sound quality Became distorted.
Right deck was freakin' possessed ..
Couldn’t stop the track playing
When I clicked the mouse pointer on the spinning vinyl The sample increased it’s speed.
I shut the software down, re-opened VDJ and played “Push It” with some distortion..
If I had time to do a complete shutdown of the computer the problem probably would have went away..
The question is, “What The Hell Was The”
Thank you
geposted Wed 06 Dec 06 @ 9:06 pm
sbangsPRO InfinityMember since 2004
i belive it caused some soundcard error and the noise kept looping
best action to take is to restart
geposted Wed 06 Dec 06 @ 9:16 pm
Thanks skyfxl. Is there something I can do with the soundcard settings to prevent any potential errors?
geposted Wed 06 Dec 06 @ 9:32 pm
i wouldnt worry about it it only happens once in a million cases
but check ur maxload setting
geposted Wed 06 Dec 06 @ 9:48 pm
djcelPRO InfinityModeratorMember since 2004
Were you in ASIO ?
geposted Wed 06 Dec 06 @ 10:02 pm
djcel wrote :
Were you in ASIO ?
What is "ASIO" and when would I use it and not use it..
What ever it's used for, No
thanks
geposted Thu 07 Dec 06 @ 12:17 am
asio, is used for tcv, time coded vinyl.
asio is a driver developed by stineberg, and it allows the dj to run in low latancy mode, for exsample if u put your hand over the spinning record, it might take a few seconds to registor that u have your hand over the record,on the other hand if u had run in low latancy mode and u put your hand over he record it would react as soon as u put your hand over he record, hope thats a good explaination!!!!
geposted Thu 07 Dec 06 @ 2:48 am
I’m using mk1 just as a controller, being that using the sound card creates issues with VDJ..
Should I ASIO drivers and would it help stabilize mk1 sound card with VDJ.
geposted Thu 07 Dec 06 @ 3:14 am
what does btw stand for?????
geposted Thu 07 Dec 06 @ 4:15 am
listen2PRO InfinityMember since 2005
btw = by the way
geposted Thu 07 Dec 06 @ 5:18 am
thanks listen2, your always a great help!!! btw i fond that eminem song we were talkin bout
geposted Fri 08 Dec 06 @ 12:50 am
