Hello,
Now I'm using bpmstudio.
After an evening playing the songs with bpmstudio it saves automatically a list of the played songs.
Is this also with virtualdj ?
geposted Thu 07 Dec 06 @ 11:56 am
yes it does this
i used bpm studio but its nothing compared to virtual dj
geposted Thu 07 Dec 06 @ 12:01 pm
You have comparison sheets for vdj editions (eJay, home edi, hercules, pro etc...) and vdj vs other dj software (traktor, bpm studio etc...) here:
https://virtualdj.com/products/comparison.html
geposted Thu 07 Dec 06 @ 3:58 pm
I also used bpm studio 4 and is a good software but vdj has more advantages one of those is the capability of mixing videos.
geposted Thu 07 Dec 06 @ 6:50 pm
Thanks for the answers.
I donloaded the latest trial version.
Is there something in the configuration that I have to mark so that it saves everything you played?
Or is this only not possible in the trial version.
Can't find an option in the configuration.
geposted Thu 07 Dec 06 @ 8:31 pm
just use the search funtion all played songs are saved
geposted Thu 07 Dec 06 @ 10:02 pm
But I ment to say:
When I play all kind of music the whole evening and when I stop and close vdj, is everything that I played saved?
So yes, where can I found this?
But I ment to say:
geposted Thu 07 Dec 06 @ 10:53 pm
two ways
most common played songs are saved in sugestions box
and playlists can be saved for you using playlist > save
aslo your record case saves all the tracks u have scanned
geposted Thu 07 Dec 06 @ 10:57 pm
