Forum: Old versions
Topic: Changing the midi key mapping of Dj Contol ?
Hi
Im quite new to this (still!) so appologies if this is the wrong terminology but is it possible to change the midi key mapping set for my Hercules DJ Control ? For example - changing it so that the dial on the top of each channel with the word 'pitch' next to it so that I can use it to alter pluggins etc ?
geposted Mon 11 Dec 06 @ 3:02 pm
sbangsPRO InfinityMember since 2004
you need to upgrade to pro edition
geposted Mon 11 Dec 06 @ 6:36 pm
You need the pro version for the on-the-fly mapper plugin for easy change buttons on Hercules.
But you can manually change midi on your version of VDJ too, by disable Hercules in the control settings, and enable general midi instead. Then map all buttons to functions. Its quite some work, but possible.. I think your version supports midi mapping :)
If not, you need pro version
geposted Tue 12 Dec 06 @ 2:36 am
Excellent. Thanks
geposted Tue 19 Dec 06 @ 2:35 pm
ciocePRO InfinityMember since 2004
No no no, only the PRO version supports midi mapping :(
geposted Tue 19 Dec 06 @ 3:31 pm
