Is it possible to use headphones on a computer for mixing with VDJ?
Thanks
Thanks
geposted Thu 14 Dec 06 @ 8:06 pm
yes you can listen using the headphone jack
or do you mean prelisten for this you will need a 4.1 + soundcard
or a usb soundcard
and pro edition;)
or a usb soundcard
and pro edition;)
geposted Thu 14 Dec 06 @ 8:26 pm
Yes you can, but you must have a registered version. This feature is not available in the demo version.
geposted Thu 14 Dec 06 @ 10:17 pm
i thaught it was a full functional demo, im i right?????????
geposted Fri 15 Dec 06 @ 12:07 am
its a fully functional demo for 20 days now
u need a good souncard mind you 4.1+
geposted Fri 15 Dec 06 @ 12:17 am
Thanks guys I am going to get the fully registered version, I just wanted to know that I could do it first. I am just starting and I wanted to make sure before I invest any money into it...
geposted Sat 16 Dec 06 @ 4:04 pm
I'm trying to understand all about VJ. How does the broadcast feature work?
geposted Sun 17 Dec 06 @ 4:47 am
geposted Sun 17 Dec 06 @ 4:55 am
ok , explain what your goal is?? if you are mixing from your lap top with out trying to buy a usb 4 in and 4 out card then you will have to asign the line if you can as a out and then use the head phones. if you have a usb sound card you send the seperate channels into a mixer and then hook your head phones in just like your playing a cd..and boom your slammin. to be honest i never use head phones because once you set cue points a head of time it knows them.. This program is so easy its incredible.. the only thing that can fail is your computer not the program , 340 nights of it on and it never crashed I did.
geposted Sun 17 Dec 06 @ 7:32 am
