Forum: Old versions
Topic: Problem with TCV. Help!
I can't make my tcv work correctly. This is my sys:
Athlon 3000+
1 gig ram
HD 150g 7200 SATAII
Maya 44 USB Driver 2.5.5
2 TT Technics MK2
1 Numark cm-200usb
2 TCV
VirtualDJ Demo
After a few moment of playing a song it start to skip randomly.
I read in a topic that this is a common problem because the TCV with the new Version doesn't work, i refuse to belive that, so please help me because i don't want to spend more money buying the program until it work.
Thank
geposted Fri 15 Dec 06 @ 3:48 pm
sbangsPRO InfinityMember since 2004
what is happening and what sound config have you choosen:)
timecode does work who ever said that should be shot;)
geposted Fri 15 Dec 06 @ 3:54 pm
After a few seconds of playing the song skip randomly and sometimes goes to the end of the track back a foward very quikly and produce a sound drop in the speakers.
My conf. is :
TCV Conf.:
Speed 33rpm
Mode smart
Lead time 500ms
Anti skip on
Software RIAA on
TCVAuto config
Maya 44 Asio Conf.:
USB Tab:
Sample rate 44.1 khz
Resolution 16 Bit
ASIO Tab:
Asio Resolution 24 bit
Application priority Normal
Sistem Performance Highspeed
Control Tab:
Monitor 1+2 and 3+4 Mute
Input Level 80%
Output Level 100%
Performance
Best Quality
Latency 512 (11ms)
Safe Mode and Overclock Off
Latency On Enghanced Algorithm Filter size 11 Filter Smooth on
48khz<->44khz Basic Interpolation
Master Tempo Fast
(the performance set up was given by a pro user Tony (he have a similar system) in the spanish forum)
Well i Hope with this information someone can help me.
Thank You.
geposted Fri 15 Dec 06 @ 9:39 pm
Set latency for AUTO in VDJ performance tab, and you are sorted ;)
geposted Fri 15 Dec 06 @ 10:07 pm
yes :-)
geposted Fri 15 Dec 06 @ 10:13 pm
