I have a music video happy hour presentation that I've been running with other software.
I have all of my playlists saved as .m3u's
I'd like to use Virtual DJ to run these playlists, but the start/end points on the automix feature ruin the presentation.
Is there any way to use automix from the very beginning and end of each file? Or will I have to manually set the start and end points for every track?
Thanks,
Patrick
Thanks,
Patrick
geposted Mon 18 Dec 06 @ 9:01 pm
add cue points at the very start and very end manualy the first time then automix will load from the start and end at the end
geposted Mon 18 Dec 06 @ 9:35 pm
I'm aware of that.
I'm asking if there's a way to auto set all start/end points to the very beginning and end of each file without doing it manually for each song.
Thanks again,
Patrick
Thanks again,
Patrick
geposted Tue 19 Dec 06 @ 12:34 am
you need to do it manualy i belive sorry
geposted Tue 19 Dec 06 @ 1:15 am
Just do this:
- FORCE FADE ON
- FADE LENGTH ZERO (or small value)
- AUTO PITCH MATCH (on or off, depending if you want the the automix to beatmatch or not)
- AUTO CUE OFF
That will play the songs from start to end...
geposted Tue 19 Dec 06 @ 1:37 am
nice one :-)
il write that down
il write that down
geposted Tue 19 Dec 06 @ 4:01 pm
Norway is there a way for someone to make a little app that will let you edit the start points and end points all at once?? That would be one nice little app.
geposted Thu 21 Dec 06 @ 12:23 am
