Forum: Old versions
Topic: Trouble with Timecoded Cd's
I just burned some Timecoded cd's and I configured my sound card and computer as needed.
But when I am play the cd players (numark axis 8) my computer says there is no signal. Can anyone help me out with this problem? I am using numark axis 8 cd players, Hercules Mk2 sound card, a dell inspiron 2650 and 2 timecode cds I downloaded from this site and then burned.
geposted Sat 23 Dec 06 @ 2:44 am
Try press autoconfig in the timecode settings
Do you see a timecode wave??
If not, open up the line ins on the hercules, in the hercules control pannel
(next to volum sliders)
geposted Sat 23 Dec 06 @ 3:01 am
I see the waves but they are all over the place and it says I have 0%
geposted Sat 23 Dec 06 @ 6:08 pm
k;)
here is the deal :
- The mk2 does not have volume slider for line ins (unfortunately).
So your signal from the CD players is too loud
What you need to do is this:
- Open the mp3 timecode in a wave editor
- Lower the signal about 13db
- Save to windows wave file (PCM)
Burn a new audio cd, and use that;)
geposted Sat 23 Dec 06 @ 6:37 pm
Thanks that worked....I have another problem now. Now my Mk2 card isn't controling my vdj software. What do you suggest?
geposted Sat 23 Dec 06 @ 10:52 pm
sbangsPRO InfinityMember since 2004
check it is enabled on the remote control tab
geposted Sat 23 Dec 06 @ 10:54 pm
I checked enable but the little light on the screen is still read indicating that it hasn't found the mk2. Also the music sounds like digital pixalated. What is a good sample rate and buffer?
geposted Sun 24 Dec 06 @ 4:06 am
try a reinstall of the console
geposted Sun 24 Dec 06 @ 4:18 am
Still nothing, does it work on any version of Vdj?
geposted Sun 24 Dec 06 @ 5:05 am
yes , but you will gett better results in the latest version 4.12 :)
look in device manager to check if the console shows up
geposted Sun 24 Dec 06 @ 1:47 pm
Do you have a link for that?
geposted Sun 24 Dec 06 @ 5:58 pm
follow the guide for irq to get it to show up
then take a screenshot
Shift + print screen :)
then go to paint and press paste :)
then save it
then upload it via
www.tinypic.com
copy as link here :)
geposted Sun 24 Dec 06 @ 6:04 pm
