Forum: Old versions
Topic: @++>>>MK1 Help
Hi ,,, Is it possible to map the button on the MK1.… I down loaded the mapper but theirs no diagram for changing the keys like the Keyboard setting…
geposted Sat 23 Dec 06 @ 8:22 am
sbangsPRO InfinityMember since 2004
the icons on the mapper match the buttons
you choose the action you would like each one to do
no sign + 0 equal activate
+ eg 1
means change the variable by one
- eg 1 means decrease
it so to mapp start to cue you would
choose that button , on the drop down menu , you would choose play
then no sign
now press apply :)
geposted Sat 23 Dec 06 @ 12:06 pm
Hi skyfxl..... I know how to adjust thing, I can't find the mapper.. I installed it but can't find it..
geposted Sat 23 Dec 06 @ 5:25 pm
look on the fx tab and the external devices page :)
geposted Sat 23 Dec 06 @ 5:46 pm
Ware do I find that??
geposted Sat 23 Dec 06 @ 6:54 pm
geposted Sat 23 Dec 06 @ 10:31 pm
Thats what I thought you ment.... It's not there.... do I need to install the mapper into vdj??
geposted Sun 24 Dec 06 @ 12:59 am
yes ensure its in the folder marked "external devices"
geposted Sun 24 Dec 06 @ 1:12 am
