there are some really good guides and tests with photos and all explained here:
ENGLISH:
www.tomshardware.com/consumer/20031111/index.html
FRENCH:
www.tomshardware.fr/articleav.php?IdArticle=451&NumPage=1
its an extended guide going through all the features of Hercules:
Introduction
Truly Portable Sound
Support, Stand
Inputs And Outputs
DJ Interface
Drivers And Hardware
The Right Software
When The DJ Is Asleep
Test Configuration And Audio Analysis
Behavior At 44.1kHz
Behavior At 48kHz
3D Sound And Games
Configuration: Minimum Requirements
In DJ D'Jill's Opinion
Conclusion
--- french ---
1. Introduction
2. Entrées et sorties
3. L'interface DJ
4. Pilotes et matériel
5. Des logiciels adaptés
6. Des logiciels adaptés (suite)
7. Des logiciels adaptés (suite)
8. Configuration de test et mesures audio
9. Comportement à 44.1 kHz
10. Comportement à 48 kHz
11. Mesures audio (suite)
12. Le son 3D et les jeux
13. L'avis du DJ D'Jill
14. Conclusion
ENGLISH:
FRENCH:
Introduction
Support, Stand
Inputs And Outputs
DJ Interface
The Right Software
Behavior At 44.1kHz
Behavior At 48kHz
3D Sound And Games
Conclusion
--- french ---
1. Introduction
3. L'interface DJ
14. Conclusion
geposted Sat 07 Aug 04 @ 3:32 pm
Some extended comments :
- Hercules works with full version of VDJ too, and add extended features to Hercules, such as jogwheel scratch.
- Hercules did have some "problems" at start, they are fixed by downloading the latest firmware and drivers for free at www.hercules.com
- Hercules in full version of VDJ supports sound output from EACH of the decks in VDJ, giving you the possibility to connect to external mixer.
- In VDJ 2.01 to make Hercules work in one-output and headphone prelisten mode, go to soundcard setup in VDJ, and brownse all the way to buttom of those setup images until you see the Hercules image, and choose that.
- In FULL version of VDJ, to get DUAL sound output, you need to select 4.1 soundcard + external mixer image in soundcard setup in VDJ
- In full versjon of VDJ you can choose in VDJ setup or in VDJ skin (some support) if jogwheels are to be in nudge (speed up/down) or scratch mode.
:) happy mixing
:) happy mixing
geposted Sat 07 Aug 04 @ 3:39 pm
