id get the usb 5.1 , one personaly
or save for an mk2
and
try 4.1 soundcard setup
and assign channels on outputs
or save for an mk2
and
geposted Wed 03 Jan 07 @ 7:38 pm
tried that...still no joy, can i go back to the older version, i mean the one i was using before the upgrade as this has stopped me from mixing completely, everything worked fien before the upgrade now i cannot do anything...what was the upgrade for, how is it supposed to improve VDJ as all i am experiencing are problems?
geposted Wed 03 Jan 07 @ 8:09 pm
the update solved and added the following
and has been very sucessful for most :)
sorry to hear of your problems :(
new timecode engine:
better scratch tracking
new HD mode for Timecode CDs
absolute mode fixed
accurate backward tracking
enhanced auto-config
adjustable auto-pitch sensitivity
retains pitch value when used in one-timecode mode
new features:
new remote control device added
new video transition: scratch, alpha
virtualfolders automatically remove duplicates
new query for plugins (maineffect*, mainsample*)
new action: timecode_mode
bug fixed:
virtualfolders rename/delete/etc refresh fixed
crackles in dual soundcard mode fixed
crash with very long ID3 comment in skin fixed
vdj latency adapts to nearest available latency on weird ASIO soundcards
absolute mode fixed
new features:
bug fixed:
geposted Wed 03 Jan 07 @ 8:14 pm
what config did you use before?
i used... no inputs, headphones, 4.1 soundcard, master/rear - headphones/front, autolatency, this is causing me proper grief now as you can probably imagine.
geposted Wed 03 Jan 07 @ 8:23 pm
and that completey doesnt work now :(?
geposted Wed 03 Jan 07 @ 8:24 pm
it works only not as it used to, before i could use the herc as an ordinary mixer, for example, having the cross fader to the left / left deck through speakers, cross fader to the right / right deck through speakers and using the headphone chanel selector buttons i was able to cue the opposite deck to the crossfader, now i can still use the crossfader as before but it doesn't cancel out the other track as it keeps coming throught the speakers also i cannot hear anything through my headphones on either deck.
does this explain my problem a bit better now?
geposted Wed 03 Jan 07 @ 8:33 pm
yes i understand
il have a think on this one and get back to you asp!
geposted Wed 03 Jan 07 @ 8:37 pm
In Settings, Did you change the Output Channels to "Master: output / Headphones/ output"?
And Outputs: to Headphones?
geposted Wed 03 Jan 07 @ 8:53 pm
I had the same type of issue with my MK1.. I switched to master out ¾ & headphones ½.
But I again I was using MK1 sound card.. Maybe selecting a different channel for master & headphones will make it work for you..
geposted Wed 03 Jan 07 @ 9:07 pm
guys, i'm not using a MKI my mistake, i was confused over the MP3 controller which i have and the MKI and MKII, sorry for any confusion.
geposted Wed 03 Jan 07 @ 9:16 pm
Sorry not confused.. Not much difference between the setup of mk1 & 2.
geposted Wed 03 Jan 07 @ 9:20 pm
i don't have either the MKI or the MKII though, that is why i thought i had caused you some confusion
geposted Wed 03 Jan 07 @ 9:22 pm
IN VIRTUAL DJ :
Main out will be at channel 1 out at your soundcard
Headphone will be at rare out..
In VDJ options, turn AUTO HEADPHONE ON , if you like 3.4 behaviour (auto choose active deck to prelisten)
If you still have issues, you need to ENABLE SURROUND SPEAKERS in WINDOWS speaker settings!
(Windows control pannel >> sound settings)
geposted Wed 03 Jan 07 @ 9:23 pm
i'll try this right now, cheers for the help!!!
geposted Wed 03 Jan 07 @ 9:25 pm
Why don’t we start over?
1. What sound card are you using?
2. What controller are you using ?
3. Are you using an external mixer?
4. In “Setting” What are your setting for the sound card? Inputs: , Outputs: , Soundcard (s): , Sound Card: (list) , Output Channels:
5.
6. Update latest VDJ Mapper.
5.
geposted Wed 03 Jan 07 @ 9:34 pm
for any one confused :-)
5.1 usb
mp3 control
no
like in the photo
5. Download the latest divers from Hercules.com.
done ;)
not related
5.1 usb
mp3 control
no
like in the photo
done ;)
not related
geposted Wed 03 Jan 07 @ 9:39 pm
is the Hercule's controller in "Dj Mode" ?
geposted Thu 04 Jan 07 @ 2:23 am
geposted Thu 04 Jan 07 @ 4:39 am
i am using a soundblaster soundcard, a hercules mp3 controller, no other mixer.
i have noticed that i can still hear track "a" when the cross fader is completely over to the right and the volume is tuned completely down...this confused me so much i decided to uninstall and then reinstall VDJ, after i had done that i still found i had the same problems with the volume and not being able to hear throught the headphones anymore (i have checked using different set of headphones, and switched headphones into master out and they work fine) also after reinstalling the software i now get a warning message telling me "database is corrupt"
can you please help me out here guys as i am getting withdrawal symptoms from mixing!!!
geposted Thu 04 Jan 07 @ 9:09 am
