Topic: How do i use AUTO BPM??
hi guys i am new to djing and this programm and i was wondering if someone coudl help me set my machine up the right way and also tell me how to use Auto BPM i have no idea. thanx.
geposted Fri 05 Jan 07 @ 9:02 am
Add songs to the play list.. Select the magic wand circle on the left. And your off
geposted Fri 05 Jan 07 @ 9:06 am
why is it that when i load one songe in deck A and while playing i add a song to deck be and it shifts to deck B automaticaly and stops palying.??? untill i switch it to player
geposted Fri 05 Jan 07 @ 9:35 am
never mind i messed with the soundcard settings
geposted Fri 05 Jan 07 @ 9:38 am
geposted Fri 05 Jan 07 @ 9:46 am
how can i use AutoBMP do i need to drag the songs into it or whats the deal?
geposted Fri 05 Jan 07 @ 10:18 am
Lets assume you have a song in deck 1 & 2,,, slide the cross fader to deck 1 and press play…. When the song is near the end at the cue point that marks the fade out, deck 2 will start and the cross fader will commence cross fading. Deck 1 will stop and reload the next song in the play list.
If you want to just automix only the two song,, just push automix button..
You can change the length of the mix in the settings/options Fade Length bar.
geposted Fri 05 Jan 07 @ 10:39 am
