Topic: External Sound Card Opinions
I've been using the Gigaport AG USB sound card for awhile now, but I've been having issues with channels dropping etc. and amd looking to switch to a more stable card for my laptop. I don't have a standard network card slot, so an Indigo DJ will not work (unfortunately) I need one that will split the audio into two channels to run into an external mixer. What is the "preferred" card to use with VDJ?
geposted Wed 10 Jan 07 @ 4:49 am
the u46dj is the most popular here , its not going to be made much longer unfortunately
aslo users have had sucess with the presounous firebox
Virtual Vinyl is aslo not far off now :)
the giga port is usualy a stable card from what i have read are you sure you dont have a possible conflict with another device ? sounds possible.
use my blog here to check it out https://virtualdj.com/blog/skyfxl/blog3753.html
Regards Simon
