I finally got tired of waiting for Virtual DJ to come up with a MAC version and i baught a MAC PRO with the new Intel Duo Core Processor and now you can get VDJ to run on them real easy with this program at http://www.parallels.com/ providing you have the Intel Processor.
Parallels allows you to run windows simultaneously with the Mac OSX software and EVERYTHING WORKS PERFECTLY!!!!!. Keep in mind you have to do a Windows Installation on the MAC then do all your updates then install VDJ. Also, if you are using ur PC/MAC for music ONLY as i am, you dont need to keep up to date with Windows updates, just as long as you have XP Service Pack 2 and dont surf the internet too much with your music pc you should be fine.
Go check it out ..... http://www.parallels.com/
the best thing since sliced bread!!!!!!
That's it for me...no more lousy PC's with crashing issues etc. I tested it and it works great. MAC ROCKS!!!!!
DJ in Miami Florida.....
www.myspace.com/thechambersmix
geposted Thu 11 Jan 07 @ 10:12 pm
I tried this a while back on my new mac book pro. You aren't able to use dual monitor mode for video mixing.
sidenote: I use bootcamp with VDJ 4.2 and it handle videos with TCCDs via a maya44 (or the serato box) very well.
geposted Thu 11 Jan 07 @ 10:15 pm
That is also another way to do it. I dont do Video mixing so i dont have display issues.... but thanks for the tip. MACS ROCKS!!!
geposted Thu 11 Jan 07 @ 10:18 pm
MAC version for VDJ is real close to being done ;)
geposted Thu 11 Jan 07 @ 10:34 pm
start yer countdown???
geposted Fri 12 Jan 07 @ 1:28 am
Norway you just gave me a hard on ;)
geposted Fri 12 Jan 07 @ 7:30 am
LOL!!!
Come on norway... COUNTDOWN! COUNTDOWN! COUNTDOWN!
=P
As far as the thread topic, don't waste your time with ANY VT software like Parallels or VMWare's "Fusion" http://www.vmware.com/products/beta/fusion/ when it comes out (VDJ for Mac will be out by then anyway... I hope).
USE BOOTCAMP to run win VDJ on your Intel Macs NATIVELY for the moment. PERIOD! =)
T.M.I, CHARLIE F1VE, T.M.I. (Too Much Information) =(
geposted Fri 12 Jan 07 @ 7:37 am
My macbookpro just started to shake uncontrollably with anticipation. How soon before I can throw Torq in the trash?
geposted Fri 12 Jan 07 @ 11:52 am
could do it today =)
torqs new controler should be called "my first dj"
its made of cheap plastic and has bright colours
geposted Fri 12 Jan 07 @ 4:30 pm
