Forum: Old versions
Topic: retains pitch value when used in one-timecode mode ?
freak52Home userMember since 2006
this should be new in v4.2 but i can't find it anywhere
geposted Tue 16 Jan 07 @ 5:58 pm
sbangsPRO InfinityMember since 2004
when you click onto the oposite deck it should automaticaly keep the pitch on the first :)
geposted Tue 16 Jan 07 @ 6:34 pm
kinda...
You need to have TIMECODE ALWAYS ENGAGED..
In other words, you need to activate the timecode on the second deck, BEFORE you disactivate the first.
This way pitch will be kept.
It has to be like this, or else VDJ would not know what pitch you where at when disengaging timecode totally...
So if you have single timecode, and its always on (deck 1 or 2, or both.. never none), it will work :)
geposted Tue 16 Jan 07 @ 6:53 pm
it's still resetting when I activate tc on the opposite deck..
geposted Wed 17 Jan 07 @ 10:40 am
