Forum: Old versions
Topic: vdj 4.2 Freezing
muzzaPRO InfinityMember since 2003
Has anyone experienced this;
Load a song length greater than max load setting and spin dac3 job backwards. VDJ will freeze everytime any song.
ie. Max Load = 5min
load a 6 min song
then spin dac3 backwards = freeze/sound loop
Bug or just my system?
geposted Wed 17 Jan 07 @ 2:35 pm
sbangsPRO InfinityMember since 2004
go to the proformance settings lower your proformance tab
and try "autolatency"
what happens now :)?
geposted Wed 17 Jan 07 @ 2:43 pm
Already done that!
geposted Wed 17 Jan 07 @ 3:02 pm
whats ur spec?
geposted Wed 17 Jan 07 @ 3:08 pm
athlon x2 dualcore 4200
OCZ DDR2 PC5400 dual channel 2gig
pci maya44
gigabyte ga-m51gm-s2g mainboard
latest mainboard bios
latest nforce chipset drivers
latest nvida grapghic driver
latest amd driver
latest amd dualcore driver
latest directx
fresh xp sp2 install
only installed VDJ software (no other software)
xp optomised for speed
xp fast user switching disabled
not mapped through sound card
disabled theme sounds
disabled wallpaper
disabled power management
disabled screen saver
disabled xp screen effects
disabled xp updates
disabled remote assitance
no other hardware except for maya44 & dac3
no internet
usb power management disabled
no irq sharing or conflicts
graphic and audio on seperate irq's
disable unnecessary services
disabled lan in bios
disabled onboard audio in bios
tried single core and dual core
small virtual paging (also tried xp recommended)
tried low performace setting
tried safe mode off & on
tried overclock off & on
and the list goes on....
VDJ 3.4 works flawlessly on this system. but i have been waiting patiently since v4.0 to take advantage of new features.
same prob exits.
geposted Wed 17 Jan 07 @ 3:26 pm
also a problem with auto playlist. i've noticed that if you set fade length other than ZERO than some songs start quarter or more than half way into songs!
Many other users have experienced the same prob.
geposted Wed 17 Jan 07 @ 3:44 pm
I can post error code that was generated and recorded by crashguard if that would help?
geposted Thu 18 Jan 07 @ 6:24 am
Sounds like a bug!
I gues you've already thought of this, but for the time being you could just extend your max load time to 30mins or something.
geposted Fri 19 Jan 07 @ 11:41 am
Thnx Andytaylor125,
You're right, it will work with maxload=30min but not reliably. Bugs out occasionaly
I can do without the upgrades & stick with a solid v3.4 but it seems that many new plugins are made for v4.x only :( so i would like to take advantage of keeping up with upgrades!!
Hopefully i will get some feedback from Dev team on this issue!
cheers
geposted Fri 19 Jan 07 @ 3:08 pm
