Forum: Old versions
Topic: Wav editor suggestions?
trido23Home userMember since 2006
I was wondering what program everyone was using to edit the tccd file to lower the db level. i have a copy of the trial version connected to a Serato interface and connected to a Pioneer DJM-800 and 2 Pioneer CDJ-1000 MK3's. If I can get this setup to work than i will buy the program for my club. The problem I'm having is after about 30mins. of spinning I lose control of the TCCD's. I thought that maybe this was because I'm running the trial version but my two friends who BOUGHT the full program are having the same problems with TCV and TCCD. So I hopped on the forum and read how the tccd file is to loud and that I should lower the db's. Can anybody up the file of the lowered db TCCD or does anyone have a suggestion for a wave editor.
geposted Thu 18 Jan 07 @ 2:51 am
Hi,
A good free wave editor is called "Audacity." (a google search will find it easily).
It's fairly simple to alter the volume in that, but if you can't work it, just leave a question here and i'll giude you through it.
Good Luck :)
geposted Thu 18 Jan 07 @ 3:43 pm
sbangsPRO InfinityMember since 2004
geposted Thu 18 Jan 07 @ 5:58 pm
lower -13db
Thats whats needed ;)
geposted Fri 19 Jan 07 @ 12:29 am
You can use adobe audition 2.0 I reduce -12db :)
geposted Fri 19 Jan 07 @ 2:59 am
