Forum: Old versions
Topic: Im getting started?!?!? HELP PLEASE!!!
sos2001Home userMember since 2007
Please read and help me, Im beginer.
I have Virtual DJ Trial, 2 TTables, 1 Mixer and Im waiting for TCV to deliver.
My computer has a basic Sound C. (1 IN, 1 OUT, 1 MIC)
Now, to be able to use 2 Chan Mixer (conected to my TTables) I would need 2 IN, 2 OUT Sound C right?
Can I install another 2X1 Sound C and use it, that way for both of my chan or not? Because I cannot find any cheap 2 IN, 2 OUT Sound C.
Another question, Lets say Im using Virtual DJ softwer with a Time Coded Vinyls (Virtual DJ, Mixer, Turntable) am I still able to controll for example speed of the song on the VDJ and Turntable at the same time?... can I still use a beatmatch control on the softwer and pitch control on the turntable at the same time!?
Another question, I heard that you cannot use this at the Club bacause of bad quality of the TCV... is that true?
Please answer. Thanx!
geposted Sat 20 Jan 07 @ 6:24 am
mainedjPRO InfinityMember since 2006
SKyfxl can answer most of those, but if you have a decent soundcard, it will sound great at a club. Don't ever use the headphone jack only.
Is your pc and laptop or desktop?
geposted Sat 20 Jan 07 @ 3:15 pm
Oh yeah, with Time Code, you will need a low latency card.
If you want a cheap way to do it, don't use timecode, although you will miss not being able to do what you really want to.
geposted Sat 20 Jan 07 @ 3:17 pm
I have a desktop computer.
Can you give me a list of the Sound Card that I can use? (Good ones)
Can someone PLEASE answer my two other questions???
geposted Sat 20 Jan 07 @ 4:57 pm
sbangsPRO InfinityMember since 2004
heya
yes you can install another card
you would choose inputs : timecode
outputs : headphones/mixer / none (up 2 u :))
soundcards : two cards
choose your two cards
and assign the correct channels
or you could buy an all in one solution such as mk2 dj console or u46dj or numark virtual vinyl
in answer to your other question , yes thats what timecode is for :)
geposted Sat 20 Jan 07 @ 5:07 pm
ps the person who said it was bad , set it up wrong..
Im a little confused... I see that Turntables have to be connected to the IN Sound Card, and Mixer to OUT of Sounnd Card but what about Turntables are they connected to the Mixer also? How they communicate? Is there any graphic where I can see how they connect?
I know my questions might sound stupid but Im begginer on this so please help
geposted Sat 20 Jan 07 @ 8:19 pm
Can I still use my mixer as I use it without VDJ and TCV?
geposted Sat 20 Jan 07 @ 8:21 pm
I have a 2 chann mixer. Does that wirk?
geposted Sat 20 Jan 07 @ 9:06 pm
you connect the turntables to the computers soundcard
then you connect the mixer to the outputs of your card/cards
and mix the output
remember to choose external mixermode
2 channel will be fine
here is a picture for a maya 44 usb card i hope it will help you visualise what i mean.
geposted Sat 20 Jan 07 @ 9:50 pm
your text and the image doesent match to me or im confused!!!
I see here Sound Card has 8 IN/OUT
and TurnTable goes 2 to Sound Card and 2 To Mixer plus I see Mixer goes to Sound Card!!!
Now if i install another Sound Card I will have 2 IN and 2 OUT but I still cant go as the image shows
geposted Sun 21 Jan 07 @ 1:40 am
