So Install vdj 3.4 with the full install in the folder for example "VirtualDJ3" then install VDJ 4.x with the full install in the folder "VirtualDJ" or "VirtualDJ4" (as you want) [you can modify the path in the install]
Finally copy the effects you need in the correct folders. But to my mind it's useless to all uninstall. Just rename the key of the folder in the Windows registry
geposted Fri 02 Feb 07 @ 3:05 pm
I see, I couldn't remember if you could direct the folder path in the install or not. At first i did not do that; I simply installed normally, then renamed that first 3.4 folder, then installed 4.1 in the usual way to the default virtualDJ folder, then renamed that one. Sorta backwards. That's why I wanna do a complete uninstall
of 4.2r1 full and 3.4 full right from scratch. There's a little overlap in file installation and some unwanted folder/file crossover going on.
Now am I making more sense. And again, thanx for your help.
geposted Fri 02 Feb 07 @ 5:24 pm
