Forum: Old versions
Topic: Virtual DJ eats up unnecessary memory.
a13nHome userMember since 2007
Hey, folks.
Thanks for the great app VDJ trial edition!
By the way I've found a bug in trial edition.
After I cloesd VDJ, it still eats up my precious mem.
You can check it by launching task monitor.
When I lauch VDJ after that, it consumes a larger amount of mem than it never should!
geposted Fri 26 Jan 07 @ 12:38 pm
sbangsPRO InfinityMember since 2004
virtual dj like any audio/visual program loads audio to ram this is what is ocuring
not a bug.
geposted Fri 26 Jan 07 @ 1:58 pm
You are missing the point.
Any app which sit in the task manager after closing it should be disordered.
You can easily check it by yourself by pressing [ctrl]+ [shift] + [esc]
geposted Fri 26 Jan 07 @ 2:23 pm
doesnt stay runnning for me .
try a reinstall
and ensure your using the latest demo
geposted Fri 26 Jan 07 @ 3:05 pm
IIRC, my version is not latest, maybe 4.1.
And this greedy bug is not found pre-4.1.
I'll try 4.2 if an appropriate opportunity arrives.
Thanks.
geposted Fri 26 Jan 07 @ 9:49 pm
yes try an offical demo of 4.2 should help alot
hope to see you with us soon :)
geposted Sat 27 Jan 07 @ 12:14 am
I believe it is finishing the Save Database after close that is why it is on, however NEVER end this process as it will end itself, if you do you will end up with a Corrupt Database.
geposted Sat 27 Jan 07 @ 12:52 am
