Forum: Old versions
Topic: How to fix choppy wave view in VDJ?
So I set up my Gigaport Sound card last night.... In the beginning it sounded terrible, cracks and pops... I read all the forums on fixing them and came across the best video of solutions.
The info on this board is priceless...
After adjusting my visual effects for best performance, checked my background services on the processor scheduling and reduced my hardware accelerator from full to none, everything sounded great.
In VDJ config. What is the best setting for GAIN? Auto, odb or off?
Here is my new issue.
I notice the wave display that streams across the top of VDJ went from smooth all the time.... to choppy with bursts of smooth? I don't know if this effects the sound, I was playing music for a few hours last night on my loudspeakers and it did not appear to be a latency issue. Everything sounded great.
My guess is when I reduced my visual settings in XP, it did something to the visual aspect of the wave streaming in VDJ?? However, that is just a guess. Maybe its something on my laptop that needs to be tweaked?
My performance table is mostly to the left. I have auto latency on, and have safe mode and overclock checked. I have fooled around a little with the slider and did not notice any benefit in sound quality sliding it from all the way left to the middle and then back? What am I missing?
Thanks for your help.
Any suggestions? Thanks. CM
geposted Fri 26 Jan 07 @ 2:55 pm
sbangsPRO InfinityMember since 2004
geposted Fri 26 Jan 07 @ 3:08 pm
Choppy visualizations and graphics acceleration set to none, I think that may be your problem. Before changing it back to full.
geposted Fri 26 Jan 07 @ 4:49 pm
try on proformance
<fastest
and "autolatency"
geposted Fri 26 Jan 07 @ 4:51 pm
The higher performance settings are for key lock (disabled by default and has a bug if disabled and re-enabled when music is not at 0%) which keeps your music from sounding like alvin and the chipmunks when you adjust the pitch; it also affects 48khz > 44.1khz conversion.
geposted Fri 26 Jan 07 @ 4:55 pm
