Forum: VirtualDJ Skins
Topic: numark cue
so can i get the numark cue skin or actual program as a registered owner of vdj? i've heard so many great things about how the cue skin is 10 times better than vdj's native skin...(no offense intended to vdj's skin....just buzz i've been readin about)
geposted Sun 28 Jan 07 @ 9:38 am
it wont run in vdj unless you edit the code to add the logo
Soooo ,,,, Why doesn’t someone do it??
think its a cue only skin for a reason
they run fine no need to edit, a logo command line in xml is the same as vdj, it just depends on which software is actually installed. They are exclusive to numark so it might be an question of if we have permission to do so.
It has the blue and red globes with time readouts and spinning animation VS the TT spinning in VDJ - other than that there is nothing more - If you want something close to it - download the VMIX5 skin - it has the globes.
http://www.virtualdj.com/addons/download.html?addon_id=2934
oh i asked and aparently it doesnt have the same logo code
but i think we lack permision
OK V mix 5 will work with VDJ and numark cue so cue skin will work with VDJ.
