can you use hercules as a sound card for time coded vinyl
geposted Thu 01 Feb 07 @ 6:17 am
you can use the mk2 is a good simple card to use
remember you need pro edition to use it for longer than 5 minutes
geposted Thu 01 Feb 07 @ 9:32 am
how is the setup, and do you need an extra sound card.
geposted Fri 02 Feb 07 @ 5:58 am
http://www.virtualdj.com/forums/58120/Hardware_Technical_Support/Guide_To_set_up_tcv_with_mk2_console__)_.html
try this but remember as a home user you are limited to 5 minutes use at a time unless you upgrade to pro edition
at a
discount
at a
discount
geposted Fri 02 Feb 07 @ 10:38 am
what kind of turntables would be best for time coded. a straight arm or curved arm. im just trying to get my info before i buy the pro version.
geposted Sun 04 Feb 07 @ 4:19 pm
thats an age old argument lol
both work fine for me
there are alot of opinions on this
geposted Sun 04 Feb 07 @ 4:39 pm
whats the difference between them
geposted Sun 04 Feb 07 @ 5:42 pm
geposted Sun 04 Feb 07 @ 7:24 pm
