I can't figure out how to disable beatmatching when using "AUTOMIX". I have just about everything disabled that I think could be it, but nothing is working. Should I go back to VDJ3.4, or is there a solution that I don't know of?
Thanks,
Wolfman
Thanks,
Wolfman
geposted Fri 02 Feb 07 @ 3:00 am
no don't go back...here are my computer specs/settings:
http://marxpro.com/vdj
geposted Fri 02 Feb 07 @ 3:41 am
It's not the same for every computer. I tried your settings, but my soundcard is different. I had to change everything back.
Thanks for trying!!!
Wolfman
Wolfman
geposted Sun 04 Feb 07 @ 12:57 am
In version 3.4 I could turn off auto BPM and that would solve the problem, but 4.2 is different.
My current settings are:
Auto Pitch Match: Disables
Auto Gain: Always 0
Auto Pitch Reset: Enabled
Auto EQ: Enabled
Auto Cue: Enabled
With the way things are going the system only decreases the tempo on Black Eyed Peas - Hey Mama by four points. Sounds great too me. I know that it has to be something simple, but I can't put my finger on it.
Any ideas????
Wolfman
Auto Gain: Always 0
Auto EQ: Enabled
Auto Cue: Enabled
Any ideas????
Wolfman
geposted Sun 04 Feb 07 @ 1:02 am
