Found this article here:
http://blogs.sqlxml.org/vinodkumar/archive/2006/01/19/4681.aspx
This is very useful if your running Virtual DJ in shell as outlined in shyfxl's blog:
http://www.virtualdj.com/blog/skyfxl/
Thanks for posting that blog shyfxl, it helped me out greatly. I created a user called "Virtual Disk Jockey" using those settings, so now every time I click on that user, it loads up Virtual DJ immediatly. Thanks tons again!
The two most important one's I use the most:
Sounds and Audio : mmsys.cpl
Display Properties : control desktop
Display Properties : desk.cpl
Display Properties (w/Appearance Tab Preselected) : control color
== ORIGINAL MESSAGE ==
RUN command shortcuts
Accessibility Controls : access.cpl
Add Hardware Wizard : hdwwiz.cpl
Add/Remove Programs : appwiz.cpl
Administrative Tools : control admintools
Automatic Updates : wuaucpl.cpl
Bluetooth Transfer Wizard : fsquirt
Calculator : calc
Certificate Manager : certmgr.msc
Character Map : charmap
Check Disk Utility : chkdsk
Clipboard Viewer : clipbrd
Command Prompt : cmd
Component Services : dcomcnfg
Computer Management : compmgmt.msc
Date and Time Properties : timedate.cpl
DDE Shares : ddeshare
Device Manager : devmgmt.msc
Direct X Control Panel (If Installed)* : directx.cpl
Direct X Troubleshooter : dxdiag
Disk Cleanup Utility : cleanmgr
Disk Defragment : dfrg.msc
Disk Management : diskmgmt.msc
Disk Partition Manager : diskpart
Dr. Watson System Troubleshooting Utility : drwtsn32
Driver Verifier Utility : verifier
Event Viewer : eventvwr.msc
File Signature Verification Tool : sigverif
Findfast : findfast.cpl
Folders Properties : control folders
Fonts : control fonts
Fonts Folder : fonts
Free Cell Card Game : freecell
Game Controllers : joy.cpl
Group Policy Editor (XP Prof) : gpedit.msc
Hearts Card Game : mshearts
Iexpress Wizard : iexpress
Indexing Service : ciadv.msc
Internet Properties : inetcpl.cpl
IP Configuration (Display Connection Configuration) : ipconfig /all
IP Configuration (Display DNS Cache Contents) : ipconfig /displaydns
IP Configuration (Delete DNS Cache Contents) : ipconfig /flushdns
IP Configuration (Release All Connections) : ipconfig /release
IP Configuration (Renew All Connections) : ipconfig /renew
IP Configuration (Refreshes DHCP & Re-Registers DNS) : ipconfig /registerdns
IP Configuration (Display DHCP Class ID) : ipconfig /showclassid
IP Configuration (Modifies DHCP Class ID) : ipconfig /setclassid
Java Control Panel (If Installed) : jpicpl32.cpl
Java Control Panel (If Installed) : javaws
Keyboard Properties : control keyboard
Local Security Settings : secpol.msc
Local Users and Groups : lusrmgr.msc
Logs You Out Of Windows : logoff
Microsoft Chat : winchat
Minesweeper Game : winmine
Mouse Properties : control mouse
Mouse Properties : main.cpl
Network Connections : control netconnections
Network Connections : ncpa.cpl
Network Setup Wizard : netsetup.cpl
Notepad : notepad
Nview Desktop Manager (If Installed) : nvtuicpl.cpl
Object Packager : packager
ODBC Data Source Administrator : odbccp32.cpl
On Screen Keyboard : osk
Opens AC3 Filter (If Installed) : ac3filter.cpl
Password Properties : password.cpl
Performance Monitor : perfmon.msc
Phone and Modem Options : telephon.cpl
Power Configuration : powercfg.cpl
Printers and Faxes : control printers
Printers Folder : printers
Private Character Editor : eudcedit
Quicktime (If Installed) : QuickTime.cpl
Regional Settings : intl.cpl
Registry Editor : regedit
Registry Editor : regedit32
Remote Desktop : mstsc
Removable Storage : ntmsmgr.msc
Removable Storage Operator Requests : ntmsoprq.msc
Resultant Set of Policy (XP Prof) : rsop.msc
Scanners and Cameras : sticpl.cpl
Scheduled Tasks : control schedtasks
Security Center : wscui.cpl
Services : services.msc
Shared Folders : fsmgmt.msc
Shuts Down Windows : shutdown
Spider Solitare Card Game : spider
SQL Client Configuration : cliconfg
System Configuration Editor : sysedit
System Configuration Utility : msconfig
System File Checker Utility (Scan Immediately) : sfc /scannow
System File Checker Utility (Scan Once At Next Boot) : sfc /scanonce
System File Checker Utility (Scan On Every Boot) : sfc /scanboot
System File Checker Utility (Return to Default Setting) : sfc /revert
System File Checker Utility (Purge File Cache) : sfc /purgecache
System File Checker Utility (Set Cache Size to size x) : sfc /cachesize=x
System Properties : sysdm.cpl
Task Manager : taskmgr
Telnet Client : telnet
User Account Management : nusrmgr.cpl
Utility Manager : utilman
Windows Firewall : firewall.cpl
Windows Magnifier : magnify
Windows Management Infrastructure : wmimgmt.msc
Windows System Security Tool : syskey
Windows Update Launches : wupdmgr
Windows XP Tour Wizard : tourstart
Wordpad : write
Calculator : calc
Notepad : notepad
Wordpad : write
geposted Fri 02 Feb 07 @ 7:33 am
I would quite like to run a VDJ shell as well, similair to Culprit's set up, you know, you click on 'DJ' or whatever and it opens up the program only.
It is possible to have it open up select programs?
For example. Behind the scenes when using VDJ I have a search panel open mapped to my music drive so I can search for tracks. Would it be possible to have a shell that opens VDJ and and search panel?
Also, when transferring music over, I'd like to be able to have something like an administrator account that would open up a browser as usual.
I guess what I'm asking is: Can you create 2 accounts with XP. One a dj account that only opens virtual dj and the other an admin account that opens the system normally?
Now that would be cool. The dj account would only open the stuff you needed to run vdj with...i.e nothing except virtual dj and a search panel. the admin account would only open the other stuff when you wanted it to.
Keep spinnin'...(",)
P
P
geposted Fri 02 Feb 07 @ 1:33 pm
Yes, that is currently what I have setup. Follow these instructions:
Start Menu -> Settings -> Control Panel -> User Accounts
Create a new account
Type in "Virtual Dj" or "Disk Jockey" or whatever name you would like
Choose "Computer Administrator"
and then make your modified changes as described in section three of shyfxl's blog, though I recommend you read the whole thing since it is all important stuff.
-Ed
-Ed
geposted Fri 02 Feb 07 @ 6:58 pm
glad it was useful :) helped me no end :)
if you have any questions just drop me a pm or post them here :)
geposted Fri 02 Feb 07 @ 11:56 pm
Does creating more than one account on xp take up alot of resources?
P
P
geposted Sat 03 Feb 07 @ 12:40 pm
no as long as you dont long them at the same time.
geposted Sat 03 Feb 07 @ 12:44 pm
