Topic: Serato & Virtual Vinyl - Page: 1
Kenny QPRO InfinityMember since 2005
Hello,
I have a few questions:
Can I use VDJ software & VDJ TCV with a Serato box?
What are the differences between the Virtual Vinyl box and the Serato Box?
I gave my 11 year old son my 1200's and an MP22 mixer (I haven't used either in years).
I am dying to get him into TCV DJing.
I was thinking, since I already own VDJ with TCV (but don't have a compatible sound card) maybe I should just buy Serato SL instead of waiting for Virtual Vinyl. This way he can use either software.
Do you think that it's a good idea?
-Kenny Q
geposted Tue 13 Feb 07 @ 7:45 pm
sbangsPRO InfinityMember since 2004
yes you can use the ssl box with vdj
however the virtual vinyl box will be more stable and has more outputs :)
geposted Tue 13 Feb 07 @ 9:49 pm
i would recommend waiting for the official box to be released.
geposted Wed 14 Feb 07 @ 1:03 am
I can't wait.
I'm ordering SSL tonight for $500 with free shipping.
If I don't like it, I can always sell it. I've seen people in Ebay get over $400 for their used SSL.
Thanks,
-Kenny Q
geposted Wed 14 Feb 07 @ 2:50 pm
NiemsPRO InfinityMember since 2006
I would have saved 300$ by just getting a U46DJ :/
geposted Wed 14 Feb 07 @ 2:56 pm
Kenny Q wrote :
I can't wait.
Thanks,
-Kenny Q
I'd give you $400 for a brand new serato.
geposted Wed 14 Feb 07 @ 5:23 pm
>I'd give you $400 for a brand new serato.>
I'll sell it to you for $400 in about a month or two if my son doesn't want it anymore.
-Kenny Q
geposted Wed 14 Feb 07 @ 9:10 pm
Rory05PRO InfinityMember since 2005
Can you use the Serato TCV with VDJ?
geposted Wed 14 Feb 07 @ 11:36 pm
yes but it has purposeful limitations such as no needle drop and 16% pitch difference
geposted Thu 15 Feb 07 @ 1:18 am
CulpritPRO InfinityMember since 2007
Indeed. I purchased Serato about a month ago. I like both to tell you the truth. I love the fact that I have both now, and dont regret purchasing them. Virtual Vinyl works great with the Serato box. I cant wait to show you guys the ata case im designing for my system. Im using a dell mini tower with a 256mb video card w/ 2 gigs of ram and a 17" flat panel monitor & Numark DXM09 Mixer all built into one case. It's ganna be sick :)
As a side note, my uncle who has been djing since 1983 (one year after I was born) has been using Serato for the past couple of years, and he said he was majorlly impressed with Virtual Vinyl.
geposted Thu 15 Feb 07 @ 1:50 am
I ordered a brand new SSL off eBay yesterday for $500 and free shipping.
I seen a listing for a used SSL (with nothing else included) that had 17 bids and was going for $480 (some people must be stupid).
I think that Having both SSL and Virtual DJ is a good thing.
Thanks,
-Kenny Q
geposted Thu 15 Feb 07 @ 4:38 pm
Thanks,
-Kenny Q
You're damn right about that.
geposted Thu 15 Feb 07 @ 8:00 pm
Mantahoe,
I like your setup.
How is the Denon mixer?
Why do you use SSL vinyl with Virtual DJ?
I also like the SKB case
-Kenny Q
geposted Thu 15 Feb 07 @ 11:15 pm
Thanks. Can you explain that in a bit more detail though? I don't really understand the pitch part. By needle drop I presume you mean dropping the needle anywhere on the TCV and it will correspond to that part of the track on VDJ.
I only ask this becasue a friend of mine is getting Serato and I want to try out VDJ TCV without having to go out and spend 100's on gear!! If I like it, then I'll go get it. But as of now, I think it's a hell of a lot to spend on two giant jog wheels!!!
Rory
geposted Fri 16 Feb 07 @ 12:06 am
i think you can only change 16% of pitch instead of the full range
geposted Fri 16 Feb 07 @ 12:16 am
the ssl box and virtual dj timecodes have no limits :)
geposted Fri 16 Feb 07 @ 12:17 am
Dj XeoPRO InfinityMember since 2005
as i understand it, with the SSL vinyls you cant needle drop and the pitch will be 6% slower (for those that are thick this means that if you have your turntable at 0% then VDJ will play back at -6%, if i have it at +3% VDJ will play back at -3%.) naturaly normal virtual DJ vinyl works exactly as your would expect........
geposted Fri 16 Feb 07 @ 12:52 am
tnx :)
geposted Fri 16 Feb 07 @ 12:53 am
that is incorrect. the ssl records are pitched off 6%. this has nothing to do with what pitch "range" you can use with ssl records. it means when you play an ssl record and the pitch on your turntable is sitting on +/- 0%, the track will actually be playing 6% slower in vdj. if you want the track to play at regular speed, you have to move the pitch slider to +6%.
this is why i don't use ssl records with vdj.
geposted Fri 16 Feb 07 @ 1:43 am
Except being able to scratch, would anyone agree with me when I say that TCV is basically to GIANT jog wheels? VERY EXPENSIVE jog wheels at that!
Rory
geposted Fri 16 Feb 07 @ 1:51 am
91%
