Forum: Old versions
Topic: ASIO/Scratch Help
mzackPRO InfinityMember since 2006
ok, I got the TCV to work great, but now when I scratch it only scratches on the reverse of the vinyl, not the forward motion......is there a setting Im missing?
Also, somehting wierd....depending on what side Im playing, "red" or "blue" deck, it sontrols the other deck......very hard to explain, but sometimes if I start and stop a record to scratch, it starts the other song??
geposted Wed 14 Feb 07 @ 4:11 am
listen2PRO InfinityMember since 2005
it sounds like you have a scratch plugin enabled, there are 2 different ones, one mutes forward the other reverse. Some skins had a button for this but also in the config too.
The starting the other deck is a bit strange sounding. what is your setup like?
geposted Wed 14 Feb 07 @ 7:44 pm
