Forum: Old versions
Topic: Still can't get 100% quality TCV
DJ CyderPRO InfinityModeratorMember since 2003
Ok I'm stumped new needle (sm144) good turntable (1200 mk2) great cables, good soundcard (waveterminal) I don't know what to do, The stange thing is the vinyl works the decks like it should, maybe I shouldn't worry but sometimes it looses the vinyl and I have to restart the program to get it back. Any ideas?
geposted Wed 25 Aug 04 @ 3:27 am
HomeboyPRO InfinitySupport ManagerMember since 2003
Have you tried these things:
Turn on the software pre amp
Try 45 speed instead of 33
Adjust the weight of the needle in small incriments
Try adjusting the volume and gain too
Also keep in mind a steady signal of any will work ok
geposted Wed 25 Aug 04 @ 8:41 am
djzeroPRO InfinityMember since 2003
make sure the volume it turned up all the way in your soundcard settings aswell, in order to get 100% time code quality on my setup the graph looks as though it is clipping.
geposted Wed 25 Aug 04 @ 9:01 pm
I've tried everything, If I turn the gain up the song skips and starts by itself
geposted Wed 25 Aug 04 @ 9:35 pm
