Topic: internal database corrupt?
dev79PRO InfinityMember since 2004
when i load vdj i get an error message saying that the internal database is corrupt. the program still loads but it doesnt show my playlists, tracks folders, etc.
what do i need to do to get the database working fine again??
geposted Thu 22 Feb 07 @ 2:15 am
cstollPRO InfinityMember since 2004
Name: runVDJ - XML Database Validator, Backup, Repair Tool
Description:
This tool provides a means to Validate, Backup and Repair your XML Database file to avoid the 'Corrupt Database' errors. 2 modes - 1 Use it as a replacement to the VirtualDJ Shortcut - this allow you to have the database validated before and after each VirtualDJ use - OR - Use it to manually validate, backup and repair your database file when you want to. - readme_runVDJ.txt file provided.
http://www.virtualdj.com/addons/download.html?addon_id=2560
Make sure you read the readme_runVDJ.txt file to understand how it works.
geposted Thu 22 Feb 07 @ 7:44 am
