Forum: Old versions
Topic: what kind of external mixer can i use.....
i recently bought vdj4... what kind of mixer can I use... i was thinking about buying a numark mixer...
geposted Tue 27 Feb 07 @ 2:01 am
bogartPRO InfinityMember since 2004
I have a numarki DM1200 mixer and it wirks fine.
Not one of the newest one out but still works. This
is a rack mounted one; but I have also used other mixer
IE stantion table top and it worked as well. There are some
newer ones out that are usb. But I think just about any
mixer you choose will be fine
geposted Tue 27 Feb 07 @ 6:49 pm
If you don't use tcv or tccd you could buy a usb mixer (it have 2 soundcards so you don't have to worry about it). I have a numark cm200usb and it's ok.(check my blog)
geposted Tue 27 Feb 07 @ 10:33 pm
