Forum: Old versions
Topic: Can't see Album Tiles
I have downloaded Trial version of VDJ4
I have 63Gb of my own music using I tunes (None of these have been downloaded)
I can see song title but no album titles in my VDJ4 Browser any idea
if I buy the full VDJ4 will this sort the problem
Help
geposted Tue 27 Feb 07 @ 3:13 pm
sbangsPRO InfinityMember since 2004
check on options you have choosen read tags/ write virtual dj tags
if you like the software please buy it to support its development
hope to see you with us soon
geposted Tue 27 Feb 07 @ 11:20 pm
cstollPRO InfinityMember since 2004
VirtualDJ currently does not support the ALBUM field from the ID3 tags. However, you could use an ID3 tag editor (Tag&Rename) and copy that data into the COMMENTS of the ID3 tags and then VDJ would be able to use that data.
Hope this isn't your only drawback to buying the software, there are plans to support ID3 tags in future releases. Best of luck...
geposted Wed 28 Feb 07 @ 1:28 pm
