Topic: Mixing with one soundcard!
Hi,
I've been using Virtual Dj for a while now and its a real nice program!
When i'm mixing i can't use my headphones and speakers at the same time, that meanes that i'll have to mix the upcoming track on the guess, i only have one soundcard, and i've tried a stereo splitter but that doesn't work also, my question to you is what can i do about this? Is there a crack for this or something like that or do i have to get a second soundcard?
Hope someone can help me!
Greetz Remco A.K.A Cazual
geposted Wed 28 Feb 07 @ 3:33 pm
Yes the crack is called - buy the program....!!!! With one sound card, you can use the OUTPUT option of HEADPHONES which then you choose Left Chan for MAIN output and Right Channel for headphones then your need to use a splitter so you can connect your headphones to the right and send the left to your AMP/SPEAKERS.
In either case, don't ask for a crack --- buy the program....!!!!
You can also buy a USB soundcard and use that as your headphone soundcard.
But you should buy the program, why not go buy the Numark CUE it comes with the program and has a soundcard set up with a headphone jack and volume control
