Forum: Old versions
Topic: SLIDESHOW WITH 4.1R2
Can someone give me a walk through on how to set the folder from which your jpg's rotate with Ver. 4.1r2? They removed the folder locator from the video tab...
Thanks!
geposted Thu 01 Mar 07 @ 7:14 am
Not sure if this is the correct method but it works when I practice with it at home (don;t use it live YET)
Click on slideshow in Video effects.
Click on open.
Click on the First Image in the folder and open
Click on the Last image in the folder and open.
Activate the slideshow, adjust slide speed to taste.
This method seems to work for me I used it with the images I used on my Youtube slideshow.
I just slapped them all in a file in MYPICTURES and used the above procedure and they seemed to cycle through just fine
Someone with more expertise in this might have a better answer.
geposted Thu 01 Mar 07 @ 11:32 am
Yup, that's it, use it all the time here, however, I just click on the first file in the folder, open and activate.
geposted Thu 01 Mar 07 @ 2:33 pm
