Who is running it? How does it work?
geposted Mon 19 Mar 07 @ 11:58 pm
I just did a fresh re-install of xp, but I'm contemplating trying out vista.
I may Boot Camp vista on here this week but I have to clear off some space on my hard drive first because vista is SUCH a lean and efficient OS. *cough* bloatware *cough". =)
I've seen the reports of how "good" it is compared to xp. That's like saying, "This is great! This case of the bubonic plague is so much more bareable!".
I may just wait until Mac OS X Leopard gets released shortly though to try out vista.
Then it'll be just like having Mac OS X 10.5 Leopard 2007 and Mac OS X 10.0 Cheetah 2001 (vista) on my Mac! =P
vista will be a "fun, blast to the past"... without the fun of course.
Leopard will be a HUGE leap into the OS future though. ;)
- VT ConQuest
(Visual Turntablist)
geposted Tue 20 Mar 07 @ 4:11 am
I'm using xp via bootcamp on my MBP C2D 2GB 160GB X1600 256MB. The operating system runs well. VDJ runs just OK.
Conquest, I hope you're not considering replacing XP for vista on your main performance machine. From what I hear, media apps run like s#it on vista. Since I'm pretty sure we use the same computer (or close), would you mind sharing a picture of your vdj performance pane? what soundcard are you using?
The two problems I currently face with my MBP/Bootcamp/XP/VDJ rig is that you are limited to using DVI or VGA for your video output. The apple s-video dongle only works in OS X. Also, if I try to play videos without my maya44 or serato box as the soundcard (using the internal card), I get some very weird audio stutters and video hangups. I would only use the internal card for a previewing tracks at home (not at gigs) but the problem is still annoying.
geposted Tue 20 Mar 07 @ 7:16 am
Well NOW I'm not! You scared me! =P
Nah, I was just gonna install it to test it out and then dump it back to xPee before a performance.
I'm just using an MK2 for right now until the Numark sound card comes out. Then I'll get a midi mixer like the Mackie d.4 and some 3rd gen vinyl.
It works with a scan converter. I have to get one of those this week because a weekly Saturday club that me and my turntablist partner Jimnastyc start this week has all of their projectors and displays connected via composite RCA video to 1 main controller box.
Anesome's probably better suited to answer that one since he uses an SSL card.
geposted Tue 20 Mar 07 @ 9:02 am
