Forum: Old versions
Topic: Filenames bad interpretation with 2.02
claxPRO InfinityMember since 2004
I just installed 2.02.
All my tracks are names like this:
Artist - Title (Version) {Year}.mp3
With the 2.0.2, the "Artists" which contain only numbers (for example "666") are now in the "Title" column.
I prefer not to use parsers. I renamed all my tracks so that names agree withVDJ.
Clax
geposted Mon 06 Sep 04 @ 7:47 am
arjunaPRO InfinityMember since 2004
Have the programmers changed the file parser? It seems not to be documented on the history page :P
Ciao!! :)
geposted Mon 06 Sep 04 @ 11:30 am
there is no change in parser (file name use in vdj)
Try delete the file mp3database.txt, start VDJ, and rescan HD for files... see if that helps :)
geposted Mon 06 Sep 04 @ 2:37 pm
New scan ... but no change :(
Another difference with other releases:
Tracks with no artist mentionned:
example: " - title.mp3"
In previous releases: the title was in the good column and there was no name in the artist column.
In 2.02, the "-" appears in the title column
What's changed ?
geposted Mon 06 Sep 04 @ 3:02 pm
djzeroPRO InfinityMember since 2003
did you previously download the updated phraser from the adons section (not the ID3 the upgraede default phraser) the installer might have overwritten this... if not try downloading it and tell us what happens.
geposted Tue 07 Sep 04 @ 12:52 am
Done. The problem is solved.
Thanks
geposted Tue 07 Sep 04 @ 5:01 am
